586,103 active members*
3,484 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Tech-Docs and Service Bulletins
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Feb 2013
    788
    Re: Doosan Tech-Docs and Service Bulletins
    This applies to Doosan MX machine.
    For the care and maintenance of the Sandvik Coromant Capto tool holding system:
    Note: The attached also has part numbers for the specialty tools needed when working on this unit.
    Attached Thumbnails Attached Thumbnails tec2008-20.pdf
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
  2. #22
    Feb 2013
    788
    This applies to the Newer Doosan MX Series
    MX2100
    MX2600
    MX3100
    The ATC Recovery procedure:
  3. #23
    Feb 2013
    788
    Flow chart for regular turret maintenance
  4. #24
    Feb 2013
    788
    APC 300 Alarm on a lathe
    How to reference home with an Absolute Position Coder (APC)
    Attached Thumbnails Attached Thumbnails tec007-03.pdf
  5. #25
    Feb 2013
    788
    To address the Periodic Maintenance Alarm
    tec2008-30.pdf shows how to clear the alarm
    tec2008-46.pdf shows how to set/change the times and add/remove line items
    Attached Thumbnails Attached Thumbnails tec2008-30.pdf   tec2008-46.pdf
  6. #26
    Feb 2013
    788
    B-Axis overhaul for an Old Style MX
    MX2000
    MX2500
    Attached Thumbnails Attached Thumbnails tec007-16.pdf
  7. #27
    Feb 2013
    788
    How to Reset the Home position on ANY Doosan Machine.
    (Note: for the exact numbers for your exact machine, you will need the Instruction Manual (AKA: maintenance and specification manual)
    This procedure shows how to gather all needed information and apply it correctly based on what hardware the machine has and the reason why the "Reset of Home" is needing to be done.
    Attached Thumbnails Attached Thumbnails Machine reference recovery_All Forms_Addended.pdf
  8. #28
    Feb 2013
    788
    How to maintain and calibrate the Q-Setter on an Lynx 220:
  9. #29
    Feb 2013
    788
    I don't know how else to answer your PM: as it won't let me...So I'll try this reply to something that you posted.
    In this thread is the "How to reference any Doosan machine"
    Call 973-618-2461 if you need to discuss further.
  10. #30
    Feb 2013
    788
    Quote Originally Posted by Michael82
    whats ur email I checked my settings and they r all good it says I can get pm from everyone
    [email protected]
    It is in the footer of every post I have...
    ...and you have emailed me before...
  11. #31
    Where can I find the procedure for replacing the clamp/unclamp solenoid on a Doosan LYNX 220 LM
  12. #32
    Feb 2013
    788
    Quote Originally Posted by Maint_Tech View Post
    If you meant cylinder then this:
    Attachment 429802
    if you are asking for a procedure for "replacing the...solenoid" they don't exist within Doosan...
    Here goes:
    1. Verify the replacement is correct.
    2. Take pictures and/or mark connections of previous unit.
    3. Remove previous unit.
    4. Install replacement unit.
    5. Verify the connections are correct.
  13. #33
    Feb 2013
    788
    How to adjust reference position for the Power Mate Manager controlled ATC and Magazine of a Doosan MX machine:
    Attached Files Attached Files
Page 2 of 2 12
  1. Replies: 178
    Last Post: 03-12-2024, 04:35 PM
  2. Doosan Daewoo ForkLift Service Manual
    By VikingCAD13 in forum Daewoo/Doosan
    Last Post: 07-02-2012, 06:52 PM
  3. Looking for a certain HAAS service tech
    By force2eng in forum Haas Mills
    Last Post: 03-07-2009, 12:31 AM
  4. Need a service Tech
    By NSC-CDN in forum Canadian Club House
    Last Post: 02-14-2009, 09:08 PM
