Re: Power supply amps
If possible I would stay away from SMPS (switching) supplies, regulated supplies are not needed for steppers and servo's and in the event of a failure they are usually tossed, so may be false economy in the end, one of the reasons I generally use a toroidal is the simplicity if you need to add an auxiliary winding or two for 24v/12v/5v supply etc.
A EI lamination transformers works as well just not as easy to modify.
Al.
Albert E.
