I have a PWM speed control that i purchased off of e-bay. It is like the one in the picture. It has a pwm output to the motor. The input says up to 160VDC or up to 110VAC. I assume that the input is rectified since rectified 110VAC is about 155VDC. I also have a treadmill motor rated at 90VDC.
Here is what I am trying to determine. I'm thinking the PWM output of the speed control will have a peak voltage equal to the input. So, if I hook up 110VAC for the input to the speed control, the peak of the PWM output will be 155VDC. Am I OK if I keep the duty cycle of the PWM output such that the "average" output voltage is below the 90VDC rating of the motor?
