High powered green laser alignment is always being used for long distance line generation working in various industrial working fields. On condition that human eyes or hands cannot reach, this advanced laser gadget has just solved the problem efficiently. The operation of green laser alignment always has no limitation of targeting distance or height, but the noncontact green reference line can reach working surfaces temporally.
This high powered green laser alignment makes the best used featured laser advantages of good direction, good coherence, high brightness. At the required working places, the projecting green reference line is very straight and brightly visible, which has just helped workers make the best line calibration and positioning in various industrial working surfaces.
This advanced line generating alignment laser is available with wide range of laser line degree from 5 degrees until 120 degrees. Users can just make free selection of required line degree so as to obtain green reference line with different line length, line thickness at different working distances.
