586,076 active members*
3,779 visitors online*
    Apr 2003
    307
    How can I cut Brass?
    I have some projects in mind that I want to make out of brass.
    Can it be cut on a tablesaw like aluminum? If so what kind of blade and lubrication would be the best?
    Bandsaw? Chopsaw? Hacksaw?
    If I was to mill out the shape on my CNC Router, what kind of milling cutters will work? Speeds, feeds, lubrication?
    I know that this is kind of general but I've never really worked it before.
    Chris
    779
    You can cut non-ferious metal with your table saw. This means Aluminum, brass etc. Just use a carbide blade with about 60-80 teeth. Raise the blade all the way up so you are only cutting with the front of the blade and move slow. You don't need lubrication.
    You can use a bandsaw, but it should be a metal cutting bandsaw because a wood cutting bandsaw moves to fast for a standard steel blade in the metal.
    I would not use a chopsaw. Not because it could not work with a carbide blade, but because of the angle the blade will hit the metal. A chopsaw will be coming down with the full diameter of the blade hitting the metal. You want to limit the amount of teeth cutting the metal. This is why I raise the blade all the way up on a table saw.
    Milling with a standard high speed mill or a carbide mill is fine. I have not used high RPM on metal because I use my milling machine for metal, and I have it set for 1800 RPM. I use a little spray of lub like WD-40 and it cuts great! If you plan to use a router for cutting brass then you will need to get info from someone else.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Apr 2003
    307
    Thanks Jeff,
    I'll just put a piece on the tablesaw and try it. I have cut alot of aluminum on it without a problem. I find that with alum you get a better cut if you use a lube stick to prevent buildup on the blade. I'm using a standard 60 tooth carbide finishing blade. Someday, maybe soon, I will spend the $60 for a metal cutting blade.
    As far as my bandsaw goes I can slow it down to 700 rpm or 5400 fpm. Do you think that is too fast?
    My router is a Porter Cable trim router and goes at 30,000 rpm. I do have a speed control for it. I also have 1/4" and 1/8", 2 and 4 flute milling cutters.
    Part of my problem is I don't have that much material to make scrap out of. But, here goes.
    Chris
    Apr 2003
    307
    I was just looking closer at the numbers on my bandsaw and they are in fpm. So the slowest I can go is 700 fpm.
    C
  1. Kcam Cut depth
    By 47MLB in forum Uncategorised CAM Discussion
    Last Post: 01-18-2012, 08:04 PM
  2. Water cut??
    By Yepez in forum Waterjet General Topics
    Last Post: 02-24-2010, 03:23 PM
  3. cut single, cut auto and cut all???
    By fastolds in forum BobCad-Cam
    Last Post: 10-06-2004, 02:15 PM
  4. PICS - BOAT HULL CUT WITH CNC
    By ninewgt in forum DIY CNC Router Table Machines
    Last Post: 08-03-2004, 12:21 AM
  5. Can you cut Al. with a wood bandsaw
    By CactusChip in forum MetalWork Discussion
    Last Post: 11-20-2003, 10:45 PM
