Having a problem with the Z soft limit warning in mach3. My mill is a G0704 CNC conversion. I have the X,Y and Z all zeroed out on the DRO for the part I am going to cut. Everything looks good then go to load the program and proceed to hit cycle start and the machine moves to a location for the tool change. I put the tool in then it moves to the safe Z location the spindle starts and then it starts going up and hits the soft limit switch on the Z axis. Here is the Gcode that is giving me problems. My Z soft limits are set at .30 and the safe Z limit is set at -.50 Machine Cordinate. Any help would would be awesome.
Jeff
( Made using CamBam - CamBam CNC Software )
( M1 AR15 side pins 3/12/2015 1:44:53 PM )
( T4 : 0.375 )
( T14 : 0.156 )
( T15 : 0.376 )
( T16 : 0.125 )
( STOCK/BLOCK,7.6875,1.304,1.0,0.0,1.304,1.0 )
G20 G90 G91.1 G64 G40
G0 x-4.0 Y0 Z0.5
( T4 : 0.375 )
( TOOL/MILL,0.375,0.0,4.3051,0 )
T4 M6 G43 H4
( Drill1 )
G17
M3 S2300
G0 X1.931 Y-0.714
G98
G0X1.931Y-0.714Z0.25
G83 X1.931 Y-0.714 Z-1.0 Q0.25 R0.25 F10.0
G0 x-4.0 Y0 Z0.5
G80
( Drill2 )
G0 X-4.0 Y0 Z0.5
( T15 : 0.376 )
( TOOL/MILL,0.376,0.0,5.6406,0 )
T15 M6 G43 H15
M3 S2300
G98
G81 X1.931 Y-0.714 Z-1.0 Q0.25 R0.25 F5.0
G0 X-4 Y0 Z0.5
G80
( Drill3 )
G0 x-4.0 Y0 Z0.5
( T16 : 0.125 )
( TOOL/MILL,0.125,0.0,4.11290,0 )
T16 M6 G43 H16
M3 S2300
G0 X3.899 Y-0.625
G98
G0X3.899Y-0.625Z0.25
G83 X3.899 Y-0.625 Z-1.0 Q0.25 R0.25 F5.0
G0 Z0.5
G0X3.056Y-0.939Z0.25
G83 X3.056 Y-0.939 Z-1.0 Q0.25 R0.25 F5.0
G0 X-4 Y0 Z0.5
G80
( Drill4 )
G0 X-4.0 Y0 Z0.5
( T14 : 0.156 )
( TOOL/MILL,0.156,0.0,4.5707,0 )
T14 M6 G43 H14
M3 S2300
G0 X3.899 Y-0.625
G98
G81 X3.899 Y-0.625 Z-1.0 R0.125 F5.0
G81 X3.056 Y-0.939 Z-1.0
G80
G0 X-4 Y0 Z.5
M5
M30
