586,115 active members*
3,554 visitors online*
    Mar 2015
    Unhappy DeskCNC software error
    Hi I was wondering if someone could point me in the right direction. I have a DIY CNC and run DeskCNC. It's been a couple of months since I used it, and now all of a sudden I developed a problem. When I go to run DeskCNC it comes up with an error on startup. When opened it goes through the normal starting process, saying it has detected the controller but then says 'command timed out'
    I thought this was a connection problem and after changing the serial cable and re-installed DeskCNC, I thought it must have been the serial port on my computer. After changing the computer and reinstalling the software again the problem is still there, arrrrrr, pulling my hair out so any help to fixing this problem would be very appreciated.
    I have a project I really need to get done ASAP, so can someone please help.
    Thanks Annie
    Oct 2020
    4
    Re: DeskCNC software error
    Hi Friend,
    I have this exact same problem now, any luck solving it?
    Sean
  1. Software Error???
    By behindpropeller in forum Haas Mills
    Last Post: 11-10-2010, 08:53 PM
  2. DeskCNC Software Probs
    By Rob 1264 in forum DeskCNC Controller Board
    Last Post: 05-04-2010, 10:07 PM
  3. Deskcnc CAM software advice
    By StephenSebastia in forum Uncategorised CAM Discussion
    Last Post: 06-25-2007, 10:07 PM
  4. Deskcnc users, what CAM software are you using with this controller?
    By Idle hands in forum DeskCNC Controller Board
    Last Post: 05-06-2006, 07:00 PM
  5. DeskCNC for Foam cutting software
    By cncadmin in forum CNC Wire Foam Cutter Machines
    Last Post: 09-26-2005, 02:44 PM
