586,061 active members*
4,583 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > Using DMM Servo to power lathe or milling spindle
    Mar 2015
    11
    Be gentle, I am new to the CNC world... so this may be a stupid question, but I will ask it.
    I have both a HF mini mill and mini lathe, both of which are in the process of being converted to CNC. In the case of the lathe in particular, I want to be able to cut threads, and I can see where having precise knowledge of the mill spindle location and speed (through encoding) would be equally useful in machining a variety of surfaces. Would I be able to use a DMM servo to power a mini mill/mini lathe spindle in this manner?
    Feb 2007
    711
    Re: Using DMM Servo to power lathe or milling spindle
    I have a dmm servo I will be using as a lathe spindle motor, not a bad idea at all.
    Make sure you get a drive that forwards the encoder signals to the control software, such as the dyn3 (dyn2 doesn't do it), so you can do threading / rigid tapping.
    Mar 2015
    11
    Thanks, that was exactly the answer I was looking for because I want to be able to do rigid tapping and threading eventually.
    Sounds like I am on the right path.
  1. Replies: 2
    Last Post: 12-30-2014, 10:28 AM
  2. Replies: 0
    Last Post: 12-02-2014, 04:13 AM
  3. Vertical Milling Center Servo Power Ratings
    By dangercraft in forum Servo Motors / Drives
    Last Post: 08-28-2014, 03:34 AM
  4. Spindle power for PCB milling
    By rbasniak in forum PCB milling
    Last Post: 05-27-2010, 01:31 PM
  5. Spindle power by servo motor
    By Stevie in forum Uncategorised MetalWorking Machines
    Last Post: 04-18-2004, 08:20 PM
