Hello All Dynatorch Users,
I posted this in a reply to Magma Joe but I wanted to make sure that all the Dynatorch users saw it. We have a new software update. BElow is a brief explanation of whats new
... Another new version of our software is now available. Version 320212 contains a new conversion algorithm for converting existing g-codes, (such as those from Burny files) for conversion to code compatible with our machine. For instance, we use G23 and G25 to raise and lower the torch, others use M3/M4 or M70/M71 or M66/M67 and even M9/M10. We also use absolute coordinates for X and Y and incremental dimensions for I and J, others use combinations of the two. We use decimal points in our coordinates, others assume 4 decimal places, but do not use the period. We can now convert most these files over in our Modify G-Code section of the Converter. We also fixed a small bug in the Library for the OxyFuel cutting. It seems some values were not being assigned when the selection was made. And a bug in the DXF converter with Ellipses was found and cured (Thanks Sam).
