Re: Looking for a super quiet 2.2kw spindle
I have posted the fact a few times here that I am running a 2.2kW Chinese "water-cooled" spindle for several years now with only external air cooling using my 1 hp HF dust collector. I was not so much concerned about leaks but wanted to avoid the hassle with plumbing, radiators or reservoirs and pumps (that may fail or clog). The high volume air stream through a shroud around the spindle has more cooling effect than the usual water trickle, anyway. I have a thermometer strip on the spindle and it never gets warmer than about 10 degC (18 degF) higher than room temperature. It takes about 5-10 minutes for the spindle to warm up to that temperature, depending on the load. This dust extractor configuration makes for an easier dust boot setup, basically just an extension of the air shroud and for most uses you will need something to avoid dust going everywhere.
I agree with other posters that the spindle noise (basically just a whirr) will be drowned out by the cutting noise for any bit bigger than 1/8" or all hard materials. I also like the fact that the spindle is safer. The starting torque is minimal and it starts up gradually within 5-10 seconds. A router goes off with maximum torque within fractions of a second. Mistakes or software problems can have a much worse result.
Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
