586,096 active members*
3,057 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > ALARM 2161 LUBRICATION OIL PRESSURE DOWN
Page 1 of 2 12
Results 1 to 20 of 40
    Nov 2007
    361
    I have a Puma 400 b it is only about 2 years old and just last week it kept giving a 2161 lubrication oil pressure down alarm . I called the doosan dealer in my area that we have come repair our machine when they go down and they said to rule out the pressure switch 1st so I did , I changed the pressure switch out and it still kept giving the alarm 2161. The pump has a gauge on it and when working properly it goes into the green and that is about 15 on the gauge ,when I get the alarm it only goes to 8 maybe 10 no where close to the green . Im thinking it could be a leak so I plug the line going out of the pump to the machine just to check the pump and it is not going up to the working pressure . Does anyone have any ideas
    Jun 2004
    511
    Re: ALARM 2161 LUBRICATION OIL PRESSURE DOWN
    Sounds like the pump is the problem, if you plug all the outlets and it still cant make pressure. Drop the tank and check to see it there is a strainer on the inlet. Doosan keeps an eye on this forum and will answer you.
    Feb 2013
    788
    check this thread:
    http://www.cnczone.com/forums/daewoo...bulletins.html
    Look at the entry labeled: "How to tell if your lube lines are leaking, or distribution ports are malfunctioning, or if the pump is failing."
    Let me know what you find (or email me a cellphone video of the gauge in operation)
    The visual speed from 0 to 8 in comparison to the speed from 8 to 15 will tell me a lot about where it is malfunctioning.
    Note: you have selected to NOT receive private messages, so I could not reply to the message that you sent me...
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2009
    6028
    Sounds like contamination in the pressure relief plunger. Pretty easy to disassemble and clean. You will need to re-adjust the max pressure when you put it back together. It's just a plug with a spring.
    Feb 2013
    788
    Unless it is a leak allowing unrestricted flow, thus limiting achievable pressure.
    Or a clog in the pick-up line.
    main line leak...pump being weak...poor pick-up...would all manifest as "slow from 0 to 8"
    fast 0 to 8, but slow 8 to 17 is a leak/malfunction in the distribution ports.
    not attaining 17 is checked by "blocking the main line" and running pump, if not 17= pump/pick-up/relief (though a sticking spring would usually manifest itself as higher pressure than desired)
    Nov 2007
    361
    OK I replaced the pump and now the 0-8 is normal from 8-17 is where it gets slow and sometimes with the new pump it does not even get to 18.
    Feb 2013
    788
    It's likely to be the distribution ports.
    Note: if the new pump made a change to the action, it was probably close to failure.
    Feb 2009
    6028
    Thought you said you plugged the output port from the pump? This would eliminate all lines and manifolds. If you didn't then id agree with replacing all the manifolds, but plugging the output is the very first test.
    Feb 2013
    788
    Quote Originally Posted by underthetire View Post
    It could be leaking at the distribution ports and the pump could have been on its last leg...
    ...the leak, if left un-attended, would have caused the pump to work harder/longer, thus wearing it out prematurely.
    Causing a dual-issue.
    Nov 2007
    361
    dhardt I have the new pump on the machine it worked good for a shift then now it is barely making it to the green on the gauge now ! What should I do , I was going to try and adjust the pressure to make the gauge go up to 15 . It is in the green but not like it should be
    Feb 2013
    788
    what is the action on the pump's gauge?
    follow this link, look at the post on how the gauge works.
    Nov 2007
    361
    action??
    Nov 2007
    361
    it works just as the diagram shows when it gets to egoing to f it goes down 1 on the gauge
    Nov 2007
    361
    everything works like the diagram it is just not going all the way to the top( top meaning it only goes to 10 on the gauge
    Feb 2013
    788
    This is a distribution port
    Blue is the incoming supply
    other side is usually blocked off, but could have another port section.
    Green is an example of where the output hoses connect.
    The Pink hovering square represents a disconnected output hose (which is what you are about to do...)
    Disconnect the output hoses from the distribution port (ALL OF THEM). Activate the pump while watching the port output. A small amount of weeping/spurting should occur, but NOT a continuous flow.
    after releasing the manual activation of the pump, the springs should inject the oil out (into the air, in our case)
    if constant flow = replace that distribution port.
    if not, re-attach the output lines and find the next port assembly and repeat this test.
    Jun 2004
    511
    What the gauge does = action
    Feb 2013
    788
    Michael, you sent me a pm, but it will not let me reply back to you
    Quote Originally Posted by Michael82
    Hey dhardt I contacted you about 3 moths ago about a puma 400b lube pump not working well I replaced the whole pump and now I am still getting the 2161 lube pressure down alarm . The pump runs good until 6 or c on the chart in one of your post , from c to the top it is slow it does not even make it to the top of the cycle it only goes to about 8-9 on the gauge the hangs up then the alarm pops up . What should I check can you help or do I need to give you more info
    The issue is in the distribution ports.
    Nov 2007
    361
    dhardt: I checked my pm everything looks good . Anyway I checked my machine this morning and it works fine do you think it has something to do with the heat it seems like the machine does this on really hot days
    Jun 2004
    511
    Michael, you sent me a pm, but it will not let me reply back to you? Do you have PM's blocked?
    Feb 2013
    788
    dhardt, I need to check my ports on the lube system I got the post you show the diagram of the port I have a question do i disconnect all the output lines or just the pink ones? my pm should work now if not post to the thread
    Remove all the output lines, either one at a time or all at once (just mark where they go if the ports are different amounts, and yes, different amounts can appear to be the same physical size)
    When trying to reply to your PM, I get:
    The following errors occurred with your submission
    Michael82 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
    If you are trying to send this message to multiple recipients, remove Michael82 from the recipient list and send the message again.
    Authorize receipt of PM's from within your account settings, or delete inbox and sendbox PM's as this site has a 20 PM storage limit.
    ...as blocked PM'ing makes my reply take more time, please refrain from using PM's with me until you sort the ability out.
    I will be happy to continue to assist you from within this thread
Page 1 of 2 12
  1. Leblond / Fanuc OM Lube Pressure No 2050 Oil Pressure Alarm
    By alcarinc in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2015, 03:02 AM
  2. Replies: 3
    Last Post: 01-07-2014, 07:12 PM
  3. 570 insufficient lubrication oil alarm
    By Asfar in forum Mori Seiki lathes
    Last Post: 05-28-2012, 06:45 PM
  4. Alarm 256 Head Lubrication Alarm
    By jb2560 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-02-2012, 03:53 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
