586,106 active members*
3,064 visitors online*
IndustryArena Forum > CAM Software > CamWorks > camworks 5 axis post ( head, head) for mach 3 src. template sample help
    Nov 2004
    70
    hi all need help on write 5 axis post head/head for mach 3
    anyone have a src file and lib. file . sample
    i had use the 5axis template in the upg , unfortunenately; the code
    did not come out as i exspected . the G code come out for table table config
    i had changed the kin file to #4 head/head and it still come out the same
    maybe some place in the lib i have to change .please help
    code for drill cycle for mach 3 sample drill on the angle
    sample
    (******************** DRILLL 2 HOLES LEFT SIDE ***************)
    G0 G54 G90 X-1.3837 Y4.807 C-90. B-15.
    G43 H2 Z2.2766
    X-1.1895 Z1.5522
    G1 X-1.1766 Z1.5039 F15.
    G0 X-1.1895 Z1.5522
    X-1.1921 Z1.5618
    G1 X-1.1637 Z1.4556
    G0 X-1.1895 Z1.5522
    X-1.1792 Z1.5135
    G1 X-1.1507 Z1.4073
    G0 X-1.1895 Z1.5522
    pivot = 4.5 " OFFSET AROUND B AXIS
    OFFSET AROUND C AXIS 3.807
    Nov 2004
    70
    Re: camworks 5 axis post ( head, head) for mach 3 src. template sample help
    HELP PLEASE
  1. Build double head laser with motorized x axis on each head
    By amders in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2015, 02:41 PM
  2. need help on 5 axis post fanuc 31i head head C B
    By plast744 in forum CamWorks
    Last Post: 12-10-2014, 01:11 PM
  3. NEWBIE NEED HELP HOW TO CONFIG 5 AXIS HEAD HEAD B/C MACH 3
    By plast744 in forum Mach Software (ArtSoft software)
    Last Post: 07-14-2014, 02:57 PM
  4. learn 5 axis camworks need sample file
    Last Post: 05-13-2010, 11:24 AM
