586,042 active members*
3,857 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Hurco M2 w/WestAmp, Convert to Mach 3
    Mar 2015
    I've got a Hurco M2 w/ a WestAmp servo drive Model #: GG802 (A6533).
    I'd like to use the current linear encoders, servo motors and servo drive. Would the step2linear boards be a fit for this application?
    Jim
    Feb 2007
    966
    Re: Hurco M2 w/WestAmp, Convert to Mach 3
    Yes they should work, but you will have to get an interface diagram for the linear encoder.
    Larry
  1. Convert eps to g code for Mach 3?
    By CNCing in forum Uncategorised CAM Discussion
    Last Post: 12-08-2014, 04:32 PM
  2. New CNC with Servos - Should I convert from NCstudio to Mach 3 ???
    By mkp007 in forum Machines running Mach Software
    Last Post: 05-29-2014, 10:14 AM
  3. convert to mach 3
    By luvpakn in forum Mach Plasma / Laser
    Last Post: 12-28-2013, 05:40 AM
  4. Prolight Turning Center convert to mach 3?
    By diyengineer in forum Benchtop Machines
    Last Post: 09-05-2013, 12:58 PM
  5. SX3 convert ..Tapping with mach 3 possible
    By Vatorman in forum Benchtop Machines
    Last Post: 02-08-2011, 05:47 PM
