Gents
good time for all
I need your help to define why The generated G code does not contain M3 to start my plasma cutter
I am using Bobcad cam v23 with windows 7 .
although the tool path is generated and verified to make the necessary toolpath but the absence of M3
got the machine moving OK but no arc starts to cut the shape. when I revised the generated G code I
found that no M3 code in the generated code .
the torch works OK when I manually with the mouse initiate the cutter through mach3 plasma wizard.
appreciate your help with my regards
