586,069 active members*
3,685 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Constant Force Spring for Counter Balance
    63
    I have read a few posts about using Constant Force Springs as an axis counter balance, usually a z-axis counter balance. Like these: www.vulcanspring.com/mechanical/stock.html
    However, I have not yet seen pictures or read of anybody actually using it in their home-made cnc machine. I have mainly seen people using gas springs.
    Have you or have you heard of any real world experience with Constant Force Springs as a Counter Balance?
    302
    When I get around to that part (the Z axis), I plan on using a pneumatic counterbalance & a 2-litre bottle for air.
    Oct 2006
    735
    The first time my gecko's fault out and my Z drops it's way to my work piece I'll give some thought to spring..
    What I was thinking is putting some sort of resistance brake of some sort to stop the screw.. Some times if the motor isn't holding it will drop and some times there is enough resistance as it sits to stay in place.. so I'd only need a small spring.
    b.
