586,036 active members*
4,277 visitors online*
Results 1 to 7 of 7
    May 2008
    83
    New Charter Oaks Enclosure Design. Whats your thoughts?
    Attached you will find an Enclosure I am designing for my CO Mill. It is similar in design to the Haas Mini Mill Currently. I am in the process of making some modifications to the design. I will be adding supports under the wings of the enclosure, as one of the upgrades. I have more stuff to do to this design. It is no way ready for building yet. Just wanted to get this out and get some feedback to help determine what other changes need to be made.
    Attached Thumbnails Attached Thumbnails Enclosure Front View.jpg   Enclosure ISO View.jpg   Enclosure Side View.jpg   Enclosure Top View.jpg
    Jun 2006
    3063
    Re: New Charter Oaks Enclosure Design. Whats your thoughts?
    Here are a couple of thoughts with no experience to back them up:
    1) I'd probably want a wider opening on the front.
    2) You might want to consider making the side windows removable with the bottom of the window frames low enough that long work pieces could be mounted to the table and protrude through the side of the enclosure.
    Mike
    May 2008
    83
    I was contemplating making the door wider. This just confirms it. I like the second idea about the windows. That never dawned on me, thank you.
    Feb 2006
    794
    I would start with a larger foot print. Better safe than having to pick it up later.
    Don
    IH v-3 early model owner
    Feb 2011
    212
    I like the over all appearance . But like above wider opening and low side windows that either are removable or slide up
    Jun 2004
    6618
    If they slide up, you can still keep most of the opening covered when machining long parts. I will agree with the wider opening.
    I thoght mine was enough with just the main tray on the stands width, however I now have to replace my doors. I will be taking back 1.5" on each side of the opening. It is actually enough now, but more will not hurt a bit.
    Mine is made out of treated 2 by 4's and 2 x 's and lined with fiberglass panels.
    Looking good so far.
    http://www.cnczone.com/forums/attach...8&d=1411141148
    http://www.cnczone.com/forums/attach...8&d=1411863265
    Lee
    Feb 2011
    212
    Hoare you guys running your z axis ball screw oil lines ? Mine goes under my machine and I would have to reroute it some how if I made an enclosure.
  1. Brand new workshop - Charter Oaks Automation or CNC Masters setup?
    By sneurlax in forum Uncategorised MetalWorking Machines
    Last Post: 06-15-2013, 10:53 AM
  2. Thoughts on my design
    By yoshimitsuspeed in forum DIY CNC Router Table Machines
    Last Post: 11-06-2012, 09:40 PM
  3. Design thoughts for a 4x8
    By Mauser in forum DIY CNC Router Table Machines
    Last Post: 08-20-2012, 04:02 AM
  4. Thoughts on MDF & Torsion Box Design
    By the__extreme in forum DIY CNC Router Table Machines
    Last Post: 03-02-2009, 07:51 PM
  5. First thoughts for new design
    By Pairair in forum DIY CNC Router Table Machines
    Last Post: 09-10-2005, 04:19 PM
