586,061 active members*
4,484 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > DANGER! RhinoCAM crashes tool on work
Results 1 to 7 of 7
    Jun 2005
    11
    See
    http://mecsoft.com/phpbb/viewtopic.php?f=7&t=2964[/url]
    When the tool has a smaller cutting diameter than the shank, RhinoCAM can crash the shank against the work.
    MecSoft tells me that this bug is in all their software, as of this date. (March 21, 2015).
    The reason we don't see it so often is that it's common to use tools like this in a situation where there is no possibility of the shank contacting the work ... for example, cutting a groove in a flat plate.
    But in my case, the work was a complicated 3D object, and I just told RhinoCAM to cut (horizontal finishing), assuming that it would do as well as possible without crashing the tool into the work. The example in the MecSoft forum is much-simplified from the real thing.
    So watch out!
    Aug 2014
    232
    Re: DANGER! RhinoCAM crashes tool on work
    Not a confidence-inspiring reply from Mecsoft was it ? I wonder how many people have crashed their mills due to that bug.
    1227
    Unbelievable!It makes a nonsense of modelling the tool in the tool library.I hope they advise us soon of the bug being fixed.
    Oct 2014
    Quote Originally Posted by routalot View Post
    All Mechsoft care about is getting new customers, not holding onto the poor suckers they already sold their crappy software to.
    Mar 2008
    683
    Quote Originally Posted by FDP View Post
    I have to disagree with that conclusion. I have always been treated by well by Mecsoft. I don't even own their software but they still worked with me getting my shop neighbor sorted out on some issues he was having with a new post processor for a new machine.
    Mar 2010
    99
    It's couple of reasons may cause tool crash
    For example, if you try pocket U sign from outside to inside, and set skim lower than stock, it causes tool crash when move to another machining area.
    This cause by Skim not affected to stock - only to model height.
    Aug 2014
    232
    Quote Originally Posted by Melkiades View Post
    The old version of Rhinocam I use often tried to plough through stock, that's why I NEVER use skim, always use clearance plane instead, and retract vertically wherever possible.
  1. Danger of collision due to tool radius
    By Zakuhai in forum SIEMENS -> GENERAL
    Last Post: 08-29-2018, 03:55 PM
  2. Auto Tool Zero Crashes Bits??
    By kb0nly in forum Mach Software (ArtSoft software)
    Last Post: 09-20-2014, 01:28 AM
  3. Danger Danger BobCAD-CAM Problem..............
    By gene8522 in forum BobCad-Cam
    Last Post: 07-27-2013, 08:51 PM
  4. Machine Crashes and Tool Explosions
    By AssassinXCV in forum DIY CNC Router Table Machines
    Last Post: 04-28-2011, 10:07 AM
  5. Replies: 0
    Last Post: 11-24-2010, 09:00 PM
