586,443 active members*
2,717 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > LV error on Spindle Start 2.2kw watercooled
Results 1 to 10 of 10
    Feb 2015
    5
    Hello,
    I just recieved my new hyunyang 2.2kw water cooled spindle and VFD.
    I hooked it all up, set all the correct parameters but when I start the spindle it starts for maybe 2 seconds then errors out with a LV error.
    Any help would be really appreciated!
    15362
    Re: LV error on Spindle Start 2.2kw watercooled
    Tewpawn
    What parameters did you use, & how have you wired the input wiring, photo etc of wiring
    Mactec54
    Feb 2015
    5
    Tewpawn
    Hello mate,
    I'm at work at the moment so photos won't be possible but I will try to explain it. I live in Australia so it is all hooked up to 240v input power.
    I have my active and neutral on R and S and earth wire going to 9 for the input. My spindle is hooked up to prong 1, 2 and 3 going to U, V and W on the inverter.
    I have checked to make sure that the spindle is wired that way too (I heard that's sometimes a problem)
    The parameters I got off another post, I used: http://www.cnczone.com/forums/spindles-vfd/117782-huanyang-chinese-vfd-settings-manual.html
    Some possible solutions that I could come up with is bridging my active to R and S and putting neutral on T or running an earth from the spindle to the inverter? I'm only new to this so I'm not 100% confident.
    Cheers for any help!
    15362
    Tewpawn
    R & S is correct & ( E or 9 in some cases )for Ground wire, do not put a jumper or anything or you will smoke the Drive, have you used my settings, or some other settings, you must run/have a Earth/Ground from the spindle to the Drive connected to the same Ground terminal that the input Ground is connected to, shielded cable for the spindle to VFD is best, for this type of install, so you need a 4 wire cable with a shield
    How many amps is your input supply capable of, try starting the spindle with the pot turned down
    You need to use my settings as some of the others that have posted settings, are incomplete
    Mactec54
    Feb 2015
    5
    Tewpawn
    Hello mate,
    I think that might be my problem. I will have to run an earth and try again. I looked under the plug and the 4th pin isn't attached to anything so I may have to put a little wire under the spindle cap to a screw in the spindle? (Hopefully)
    My input supply is 10amp. And I did use all the parameters.
    I'll give the earth wire a go tonight and let you know!
    15362
    Tewpawn
    Your input is to low, you will need a minimum of 15amps 20amps would be better to be safe, the Ground/Earth wire won't be causing your problem, but you need this to be safe, yes you need to attach a Ground/Earth wire inside the cap, or on the outside will work also, make sure your O'Rings are sealing well
    As I said try starting it with the pot turned right down, then slowly increase the speed
    Mactec54
    Feb 2015
    5
    Hey mate,
    I'm going to take it to work tomorrow and give it a go. Hopefully that will be my problem!
    I'll let you know.
    Cheers
    15362
    Quote Originally Posted by Tewpawn View Post
    Check your parameters also, Here are the parameters you need set
    Huanyang Mactec54
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220/240
    PD011=120 (Minimum Setting 120)
    PD009=15
    PD010=8
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Accel=12 ( Adjust to suit)
    PD015 Deccl=12 (Adjust to suit) ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage )
    PD142=9 ( Motor Max Amps) (Set for your motor Amp Rating 2.2Kw Spindle 9 amp Max)
    (Set for your motor Amp Rating 1.5Kw Spindle 7 amp Max)
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    Mactec54
    15362
    Tewpawn
    You can also try R & T plus Earth/Ground on the input but no jumpers, if this does not run at your work you may have a faulty drive
    Mactec54
    Feb 2015
    5
    Tewpawn
    I think I may have a faulty drive. I tried on 15amp power and still the same problem. I will get in touch with the person I bought it off and see if I can get it replaced.
    Thanks for your help!
  1. Replies: 2
    Last Post: 11-07-2014, 02:15 AM
  2. start up error
    By markjb in forum Milltronics
    Last Post: 11-16-2012, 03:25 PM
  3. START UP ERROR
    By cnckid in forum Cincinnati CNC
    Last Post: 12-13-2011, 05:34 PM
  4. MH 800 C start up error
    By preimerx5 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-03-2011, 01:57 PM
