586,047 active members*
3,619 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Help please with stepper motor driver setting and mach3 steps per
Results 1 to 12 of 12
    Feb 2015
    9
    Hi, I’m new to the cnc world and would appreciate some help setting up my machine properly. My set up is as follows:
    DB25-1205 Break out board
    Nema 23 stepper motor model
    23HS9430B step angle 1.8 degrees
    Stepper motor driver--DM542A
    Questions:
    1. What should be my pulse / rev?
    2. What should be my setting in Mach3 steps per?
    Feb 2015
    9
    Re: Help please with stepper motor driver setting and mach3 steps per
    Bump
    Nov 2013
    50
    dja9520,
    Definitely not the authority on this, but what do you have your stepper motor driver microsteps set at? Also do you know the pitch of your leadscrews or ballscrews? Without those 2 pieces of information, it's hard to give you an answer. Once you have that info, you should be able to input your info into the excel doc on this page: STEPS PER UNIT CALCULATOR
    Zach
    Feb 2015
    9
    How do I determine the pitch of the ballscrews? It takes 5 revolutions to move 1 inch.
    May 2009
    37
    Then the pitch is 0.2 inches. Do the steppers drive the screws directly or is there any pulley reduction?
    Sent from my iPad using Tapatalk
    Nov 2013
    50
    What drivers are you using?
    Feb 2015
    9
    The steppers drive the screws directly. The stepper drivers are DM542A and per the factory schematic pul/rev is on 1600. When I calibrate steps per in Mach3 it sets them at 6400. Thanks again Joe
    Feb 2015
    9
    bump
    May 2009
    37
    What do you mean by factory schematic? And what do you mean by calibrate in Mach 3? With those screws you need 5 turns to move one inch, which is 1000 whole steps using 1.8 degree motor. So if you set the microstepping to say 16 on the dm542, Mach3 steps per unit will be 16000.
    May 2009
    37
    Dunno why one bothers really...
    1695
    If the dm542 is set to 1600 pulse per rev and your screw is 5 rev per inch, then Mach should be set to 8000.
    Dec 2014
    103
    You can click on the settings tab and use Axis Calibration you tell it what axis to move and how far then it ask you how far it moved and it sets the steps for you
  1. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  2. Setting up Mach 3 with a 3 Axis TB6560 Stepper Motor Driver
    By Try&TryAGAIN in forum CNC Machine Related Electronics
    Last Post: 07-17-2012, 11:48 AM
  3. difficulty setting steps per unit in mach3
    By Josh Leber in forum Machines running Mach Software
    Last Post: 08-04-2009, 10:57 AM
  4. What causes a stepper motor to jump steps
    By erkiwi in forum Stepper Motors / Drives
    Last Post: 02-20-2008, 08:26 PM
  5. Replies: 7
    Last Post: 01-02-2005, 09:41 PM
