586,069 active members*
3,946 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Current motherboards which offer parallel ports
Results 1 to 10 of 10
    Aug 2014
    42
    I've found a few motherboards which offer parallel ports. They're small, with cheap hardware.
    Like these, which have almost the exact same hardware:
    http://www.newegg.com/Product/Produc...82E16813157498
    BIOSTAR J1800NP Intel Celeron J1800 2.41GHz Mini ITX Motherboard/CPU/VGA Combo - Newegg.com
    Open Box: ASUS J1800I-A Intel Celeron Dual-Core J1800 Mini ITX Motherboard/CPU/VGA Combo - Newegg.com
    Or these, which are a bit different:
    ASRock AD2550B-ITX Intel Dual-Core Atom D2550 1.86 GHz Intel NM10 Mini ITX Motherboard/CPU/VGA Combo - Newegg.com
    GIGABYTE GA-E2100N AMD E1-2100 APU 1.0GHz Mini ITX Motherboard/CPU/VGA Combo - Newegg.com
    http://www.newegg.com/Product/Produc...82E16813157565
    They're all fanless, which keeps the crap out. I've got an appropriate enclosure. I actually think it's the same enclosure Tormach uses. Could use a solid state drive.
    These should have enough power, but I'm curious what else I should be looking for in a dedicated LinuxCNC system.
    Feb 2008
    644
    Re: Current motherboards which offer parallel ports
    Quote Originally Posted by burdickjp View Post
    ASRock D1800B-ITX Intel Celeron J1800 2.41 GHz Mini ITX Motherboard/CPU/VGA Combo - Newegg.com
    There are actually many J1800/J1900 motherboards that have parallel ports but some just have a header rather than a DB25 connector so may require an adapter cable
    Note that these are quite a bit faster than the Atom D25XX series (as is the last MB link which is a AMD)
    These are all fanless and have a LPT port on the motherboard: (you can always add a PCI pr PCIE parallel port to other motherboards as well)
    http://www.newegg.com/Product/Produc...82E16813157494
    http://www.newegg.com/Product/Produc...82E16813157497
    http://www.newegg.com/Product/Produc...82E16813157513
    http://www.newegg.com/Product/Produc...82E16813157495
    http://www.newegg.com/Product/Produc...82E16813128688
    http://www.newegg.com/Product/Produc...82E16813157546
    http://www.newegg.com/Product/Produc...82E16813138412
    Aug 2014
    42
    Is there any advantage to an onboard parallel port, versus using one of the many PCIe cards designed for CNC control?
    Cost is obviously an advantage of just using the parallel port.
    Feb 2008
    644
    Yeah lower cost and perhaps lower profile are advantages of onboard ports. they also are at known addresses so
    less fiddly to set up than plug-in PCI/PCIe parallel ports.
    If you mean a purpose built CNC oriented plug in card vs a parallel ports thats a whole different kettle of fish
    Aug 2014
    42
    Quote Originally Posted by PCW_MESA View Post
    How about we limit the comparison to things using the parallel port connector, such as the Mesa 6I25 board: Mesa Electronics
    What would be the advantage of the Mesa board over using a system with a parallel port?
    Feb 2008
    644
    Something like the FPGA based 6I25 allows higher step rates (to 8 MHz in the 6I25 case) and lower jitter that the
    parallel ports software generated steps, usually improving smoothness and top useful rapids speed.
    The 6I25 can also count high resolution incremental and absolute encoders (SSI,BISS and Fanuc), generate
    high resolution PWM, and has SPI and serial options as well for I/O expansion.
    Aug 2014
    42
    That's a fantastic answer. Thank you very much.
    Sep 2015
    12
    PCW-MESA do you have any experience with any of the boards you listed with the 6I25 card? Any hiccups to be aware of?
    Sorry to raise a necro thread.... looking at building a new controller.
    Dec 2005
    596
    Quote Originally Posted by NMay View Post
    I would hope he has some experience with the boards. He's the one who makes them.
    Feb 2008
    644
    Compatibility problems are pretty rare with the 6I25, mostly older MBs with X16 PCIE slots that dont implement X1 properly
    I would expect all J1800/J1900 MBs to just work
  1. Parallel Ports
    By DY123 in forum Momus Design CNC plans
    Last Post: 11-11-2012, 03:44 PM
  2. Question about Parallel Ports and Stepper Systems
    By Tom Kay in forum Stepper Motors / Drives
    Last Post: 09-28-2012, 06:17 PM
  3. 2 Parallel ports
    By DrStein99 in forum LinuxCNC (formerly EMC2)
    Last Post: 08-12-2010, 01:58 PM
  4. Parallel ports
    By itsme in forum Computers / Desktops / Networking
    Last Post: 10-01-2005, 02:20 AM
  5. 3.3 V vs. 5 V TTL on parallel ports
    By HansM in forum DNC Problems and Solutions
    Last Post: 07-28-2005, 08:28 PM
