Hello Stutank,
Thank you again. I did change to radius mode which now gives me the correct results.
For feeds I used the calculator in Ezilathe. See attached. I know they were running these on a Mazak for us. Time was less than 5min including flipping the part and drilling and tapping the other end.
Attachment 308880
I think I am now to a point where I can do a dry run in the air. I will at least be able to determine if their calculated time is correct, if the feed speeds appear slow, or if the rapid feeds appear slow. I will let you know how it goes.
