586,508 active members*
2,784 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > DIY 5 axis big CNC Router Head/Head
Page 1 of 2 12
Results 1 to 20 of 22
    Mar 2014
    6
    Hello to everyone. First, sorry for bad English. I am Arman from Armenia. Want to introduce my latest project - 5 axis CNC router with rotary head... Here is videos, later I will add pictures if interest...
    P.S. Could not add more than one video, so everybody can see other videos on my channel on youtube...
    Here are some pics so far...
    Attachment 274130 Attachment 274132 Attachment 274134 Click image for larger version.
    Jun 2014
    49
    Re: DIY 5 axis big CNC Router Head/Head
    Wow, this looks great. What do you make with it? Is this your own design?
    Mar 2014
    6
    Thank. I made this CNC for my friend. Hi is going to make mostly chair backs. And yes, this is my own design. I made this CNC 100% from scratch and alone. It was very hard...
    Jun 2014
    49
    Quote Originally Posted by skedram View Post
    That is seriously impressive.
    Aug 2006
    87
    Very Impressive! I would love to see more.
    Mar 2009
    39
    Agree with others,seriously impressive.Congratulations.
    Work area? Head design? -belt or gear drive,bearings.How long to build? Please show more pictures.
    Looks big enough to do car bodies(in sections) or similar.Amazing.
    Thanks for showing us.
    Mar 2014
    6
    Work area is 3500*1800*600mm. B/C rotary head angles - 0/+500 degrees for C axis, -125/+125 degrees for B axis. I used two harmonic drive gearheads with 1/101 reduction. Have ordered them from china supplyer, and now I have problem with one of them, and the problem is vibration. The building process takes from me about 6 months. Here below more pictures of building process.
    Attachment 274366 Attachment 274368 Attachment 274370 Attachment 274414
    Attachment 274374 Attachment 274376 Attachment 274380 Attachment 274404
    Attachment 274382 Attachment 274386 Attachment 274390 Attachment 274400
    Attachment 274392 Attachment 274394 Attachment 274396 Attachment 274398
    Attachment 274364 Attachment 274372 Attachment 274378
    Attachment 274384 Attachment 274388 Attachment 274402
    Attachment 274406 Attachment 274408 Attachment 274410
    Attachment 274412 Attachment 274416
    1050
    Thats really Nice work - keep us posted if its working now - on production.
    Can you give us some more details on what servo motors you have used. and how much the ATC spindle cost you.
    Jan 2013
    228
    I see how you determined the maximum height! What did you do to ensure the 4 rails on the long axis were aligned?
    Jan 2007
    1795
    building this... its more than a """DIY"" project..
    all i could say, if you invested this tremendous work, the height should be taller.. the 600 mm height sounds too little..
    either way , lowering the floor in the workarea, or raising the ceiling could be a viable solution..
    this machine worth more than a simple building, and works are dont coming as ""max 600 mm"""
    my another opinion, for chair backs... this machine too much.. , but you can build boathulls, or custom patterns for vehicle parts, like fenders.. this machine just too expenses for chair backs :-) mightbe some foampatterns for aircraft parts, like wings..
    Oct 2006
    340
    Incredible.
    Apr 2006
    1016
    skedram... very cool build we have get more photo of your 4, 5 th axis..
    I have been seriously thinking about building a 5 axis machine also, but have found very limited info/ no posts ... about setting up a atc spindle on cnczone with mach
    Can you share, with us the techincal details for the phnematic solinode and ie schematic the type valve you used etc how you wired it to the bob.. and perhaps a video showing how your atc phnematic and solenoid you used.
    Dec 2013
    25
    Awesome work!
    What size servos motors did you use on all your axis?
    This is by far the coolest 5 axis machine built from scratch I have ever seen. I am in the middle of designing a 5-axis machine, still at least 2 months out before I start ordering parts. Thanks for the pics.
    Mar 2014
    6
    Quote Originally Posted by contactirfu View Post
    The servos I used are Delta ASDA-B2 1Kw. ATC spindle is Chineese copy of HSD and costs to me is about 5000 dollars.
    Mar 2014
    6
    Quote Originally Posted by victorofga View Post
    Thanks. I agree with you about height, but all is done, and have what we have... So, maybe next time, if this next time will come...
    About building boathulls, or custom patterns for vehicle parts, I can say that our country is too small for that...
    Mar 2014
    6
    Quote Originally Posted by eloid View Post
    I am far away now from this CNC, but will take more photos when able... You are right about limited info about ATC and so... I will give you all information you asked little later
    Jun 2017
    14
    Oh, it's really amazing. You weld this big machine body by yourself? How you ensure levelness of this 5 axis cnc router
    Apr 2006
    1016
    What post processor are you using with mach3, what software are you using to generate 5 axis cam g files
    Apr 2006
    1016
    Can your share your electrical schematic and pnuematic schematics
    Apr 2006
    1016
    I know you finished this cnc some time ago... any pictures of your long y axis rail alignment ie right side left side of machine frame
Page 1 of 2 12
  1. Replies: 1
    Last Post: 03-20-2015, 01:52 PM
  2. Build double head laser with motorized x axis on each head
    By amders in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2015, 02:41 PM
  3. need help on 5 axis post fanuc 31i head head C B
    By plast744 in forum CamWorks
    Last Post: 12-10-2014, 01:11 PM
  4. NEWBIE NEED HELP HOW TO CONFIG 5 AXIS HEAD HEAD B/C MACH 3
    By plast744 in forum Mach Software (ArtSoft software)
    Last Post: 07-14-2014, 02:57 PM
  5. 5 Axis Rotery Head Home Cnc Router
    By mace in forum DIY CNC Router Table Machines
    Last Post: 09-18-2003, 05:29 PM
