586,052 active members*
3,953 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Lost Machine and Post Processor lists in Post Process
Results 1 to 7 of 7
    Jun 2007
    9
    Hi, Can you tell me how to get my machine and post processor lists back into their windows in the Post Processor window? When I try to select either the drop down only says none. I cannot post anything. Also the inch tool crib doesn't show up in tool selection it defaults to metric, and to find inch I must type in the entire path. I tried reinstalling but it didn't work. This all happened after a crash with a large file. Thanks, Mike
    Apr 2003
    1357
    Re: Lost Machine and Post Processor lists in Post Process
    Jun 2007
    9
    Thanks, some machines are there. there are no postprocessors in the post processor folder. where do I get them?
    Nothing seems to stick. When I go into post I can't get machines or post processors, and it won't let me search for them.There are no defaults or choices. everything used to be there, now there is nothing.
    Apr 2003
    1357
    Did you have custom posts? If so, hopefully you made a backup of them and you can copy them back in. Ditto for custom machine files. Maybe I'm overly cautious, but I have copies of all my customizations for Rhino and madCAM in at least 4 different places, including off-site.
    I would suggest re-installing madCAM to get the proper files back in place. It's odd that you lost the files in that C:\ProgramData folder. A re-install is quick and easy, and might be the best solution.
    Dan
    Jun 2007
    9
    Thanks, it worked this time. I had to get the folder locations into place, they didn't set up with the re-installation, but it seems to be working. Thanks again.
    Apr 2003
    1357
    Okay, good.
    Dec 2011
    97
    I have the same problem. The files are fine, but in Options..Machine, the Tool Library and Post Processor locations can't be saved. In the Post Processor dialog, there are no Post Processor choices.
  1. Custom Machine Process Definition / DATRON MCR Post
    By tcom-frazzled in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-03-2014, 01:02 PM
  2. Post processor for HAAS and Fagor machine
    By Namnp2007 in forum Mastercam
    Last Post: 08-11-2008, 03:06 AM
  3. Machine Post Processor Support
    By nlh in forum Dolphin CAD/CAM
    Last Post: 04-03-2007, 04:18 PM
  4. post processor for spectralite machine
    By lapoltba in forum Benchtop Machines
    Last Post: 12-13-2006, 06:15 AM
