101 means 'clear memory'
that happened because you turned the power off while it was doing something in the memory.
to clear it....
1) Set PWE = 1
2) Power Down
3) Press and hold "Delete" Key
4) Power up the control
5) Part programs will be deleted (parameters and everything else will remain the same)
Another manual says 'press program and then reset together'
it will do the same thing, just delete all programs in memory.
now power-cycle the machine. the alarms should not come up again. if they do something else is suspect.
the punch/read softkeys are accessed by pressing the right-most arrow key. My guess is you did not press right to get to the correct menu.
