I built a CNC milling machine I want to use as a 3d printer and cnc mill. I am using Arduino Mega and ramps 1.4 with lcd and sd card reader. I am running repetier firmware and repetier host. I am using TB6560 stepper drivers instead of the A4988. The problem I am running into is that when I connect to the board with repetier host I get an error message "the board is not functioning", when I disconnect the TB6560 drivers from the board, repetier host connects to the board without problems.
I connected the TB6560 drivers with the RAMPS board as follows:
STEP to CLK+
DIR to CW+
EN to EN+
CLK-, CW- and EN- to GND
What could be the problem in this case?
