586,112 active members*
2,999 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > Weird PP networking behavior? Works when client is wired but not on wifi?
Results 1 to 6 of 6
    Nov 2005
    218
    So... I have my PP networked but have noticed that my CAD/CAM machine (a Mac) will only see the PP samba share when it is hardwired into the network. If I am on wifi it won't see it at all even though the mac and PP are on the same WiFi net?
    Has anyone seen anything like this?
    Re: Weird PP networking behavior? Works when client is wired but not on wifi?
    I'm on a mac, wireless, I can see the share, but cannot connect to it at all. I go into windows via parallels and can connect fine.
    So I have wrote it off to something strange with the mac connection method or something. If you get any further with the Mac I would be interested.
    Donald
    Dec 2013
    267
    Are you using the Tormach USB wifi adapter?
    I tried a few others I had lying around with PathPilot (Ubuntu 10.04) and did not have luck getting them to connect. This was outside of the PathPilot application when booted into Gnome and configuring both through the GUI and the terminal. After ordering a similar $10 USB nic to what Tormach sells, everything works perfect with no special configuration and acquired a DHCP lease almost immediately.
    Nov 2005
    218
    I am, but even if I were not, that should not be the problem, should it? Remember my issue is on the mac side, not the controller side.
    Dec 2013
    267
    Quote Originally Posted by jcposada View Post
    I wouldn't think it would be on the Mac side since it works with an ethernet cable and not a USB wifi nic. If it were truly on the Mac side, the Mac wouldn't care what type of network connection the TMC had. From the Mac's perspective, the TMC is just an IP address out on the network regardless of connection type.
    I would begin by checking your DHCP server (probably your wifi router) to print a list of all clients connected. Check to make sure the TMC is actually connected to the access point (router) and has acquired an IP address lease (usually on a status page on your router).
    I believe this is also a method to check the status from inside of PathPilot, but I won't be able to check until tonight.
    Apr 2013
    1788
    Another possibility is that on your router you have blocked traffic between WiFi connected devices. I believe that blocking is the default mode for Draytek (and probably many other brands) of routers.
  1. Hitachi m12vc weird behavior when attempting to touch off
    By rlrhett in forum DIY CNC Router Table Machines
    Last Post: 12-20-2014, 10:58 PM
  2. Weird behavior and crashes...
    By subnoize in forum MadCAM
    Last Post: 07-14-2014, 10:42 AM
  3. Replies: 17
    Last Post: 04-07-2013, 04:34 PM
  4. Weird Cutting Behavior. OMC Controls
    By EricMFG in forum Fanuc
    Last Post: 08-21-2012, 01:59 AM
