Does Anyone Have A Post Processor For An Okuma Lathe
With An Osp 5020l Control For Surfcam
Yes, i got post for it
it work very good
Does anyone have post for Surfcam velocity Agie wire edm?
agie 2axis post..
would you be interersted in sending in to me
or attaching it here
it is attached here..
AGIE.zip is in my post above.
sorry about that i was talking to sang sys about the okuma post
Post for ACT35
It work very good.
Question email me.
Does anyone have the Post Processor for Agie CNC 100 that works in BoBcad 16.1 Wire.
Bobcad will create the post for you, just contact them..
Thanks for the reply, however Bobcad told me today I would have to upgrade they no longer support V16.1 Wire.
Hi, does someone know which Surfcam Postprocessor might work with a DeskCNC setup ?
Daniel
DeskCNC setup? sounds like it's software.. you would need to find a post that outputs the 'gcode' for your machine.. from looking at deskCNC's manual, its probably close to fanuc/haas.. I would start with one of those, and then edit it as needed..
Hi tnik, thanks for hint. DeskCNC is actually CAM/CNC software + controller hardware.
anyone have a haas lathe post with canned cycles?
señor. buenos dias porfavor yo tengo un cpu de torno cnc marca intertech 42-170 y el cpu es syntec baby2 queria saber si usds. tienen uno para venderme o el renplazo que paso la pila de litium se gasto la cambiamos y y la pantalla nos pide inserte diskest mi telef. 01-4582591 preguntar por ing.diaz o escribir al [email protected]
