In advanced line measurement working fields, more and more people would like to choose 532nm green line laser alignment to make line generation in various industrial working fields. Owing to its most visible and brightest green laser beam emitting, this advanced alignment laser line always bring workers the most accurate and precise line generation result on all working surfaces efficiently. With high quality standard making, this green laser alignment also passes through ROHS, CE, FDA international safety approval. Whatever kind of working occasions, it is just efficient enough to make the best line generation.
This line projecting green laser alignment adopts pen style design. It can be easily installed and operated in working surfaces. Usually users can try to mount it required machine or devices with mounting bracket. It is always allowing 0.5m to 3 meters installation height. Only if users have made correct adjustment of targeting direction, this alignment laser line will make high efficiency line positioning in operation. It is widely used in car wheel alignment, textile garment cutting, PCB processing, building construction etc.
Technical data:
Name: Berlinlasers Green Line Laser Alignment
Wavelength: 532nm
Laser Beam Mode: TEM00
Output power: 5mW -100mW
Power Supply: DC input power supply (3V-5V)
Advantages: low energy consumption, high accuracy, no mistake, high straightness and high brightness line alignment
