586,075 active members*
3,803 visitors online*
Results 1 to 16 of 16
    Jun 2011
    26
    motorcycle sprockets
    I want to have two sprockets made, look at the Picture
    The small i like to have enlarged from 14 tooth to 18
    And the big i like to have reduced size from 48 tooth to 35
    Material is unknown strong and Heavy.
    The small sprocket weight 105g
    All i know about the big sprocket today is that the distance between the mounting holes is 50mm
    Nov 2005
    218
    Re: motorcycle sprockets
    Do you have drawings or a spec, or access to the original parts? What material? What is your timing?
    Jun 2011
    26
    Nov 2005
    218
    Is this a motocross sprocket?
    Jun 2011
    26
    Quote Originally Posted by jcposada View Post
    No
    Nov 2005
    218
    Do you know the chain size?
    Jun 2011
    26
    You see the picture imeasure 7,3mm width.
    Nov 2005
    218
    um, sorry there is no picture of the chain. Chains are specified according to pitch, inside diameter and roller width. I think you are going to need to do some research in order to get parts that fit.
    Feb 2009
    6028
    Looks just like my Suzuki drz sprocket set up. Its going to be quite expensive to have them made, especially the transmission sprocket. Pretty sure the small sprockets are heat treated as well.
    Jun 2011
    26
    Is better to measure the sprocket-delves or the Chain rollers width?
    Jun 2011
    26
    Jun 2011
    26
    Ok i did some Research on the Chains.
    this is a 428 Chain
    12.7mm Pitch.
    8.5mm roller diametre.
    Jun 2011
    26
    Jun 2011
    26
    request have changed.!
    Waiting answer for a front sprocket 19tooth.!
    Then the rear sprocket will have to be measured for fittment to not make pressure to the swinging arm!
    Nov 2005
    218
    Thanks for the information. Now I need accurate dimensions for the splines the sprocket mounts onto.
    Jun 2011
    26
    31mm for the 19tooth.
  1. Where to buy Sprockets, pullies, etc...
    By thyNemesis in forum Want To Buy...Need help!
    Last Post: 10-25-2012, 04:20 PM
  2. Sprockets
    By Joezx10r in forum Mastercam
    Last Post: 02-20-2009, 05:59 PM
  3. sprockets
    By Vicros in forum Solidworks
    Last Post: 07-06-2007, 01:50 PM
  4. Sprockets
    By Harrisan in forum Fanuc
    Last Post: 03-04-2007, 09:18 AM
