586,102 active members*
2,947 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Using a proximity sensor as a tool height setter...
    May 2012
    I'm thinking about using a npn proximity sensor to set my tool height.
    I'm using a 1.5kw spindle on a cnc router table and the tool is not grounded.
    Has anyone successively done this?
    Thx.
    May 2005
    3920
    Re: Using a proximity sensor as a tool height setter...
    I haven't but I'm not sure you will get the required accuracy with a prox.
    A long time ago we used precision switches from these guys: Precision mechanical switches | Baumer Group. You would have to build a fixture to probe against and to protect the switch from over travel. At a minimum that requires a mounting block, plunger, spring and some miscellaneous parts. We could get 1 micron repeatability with the fixture in good condition.
    1943
    Since the ends of different tools will present differently to the prox sensor, the height won't be consistent. What I mean is there will be more or less metal presented to the prox because of the different flute/end geometries. As for the prox being accurate, I use them as limit/home switches on my mill and I tested them for repeatability using a dial test indicator and they are repeatable to about 0.0003" if presented with the same target each time.
    Oct 2013
    62
    Use a mechanical switch plunger type but first check out your skip signal.
    Proximity will not work properly.
    Feb 2020
    5
    Hi, what about your problem? Have you solved the problem? I just stumbled upon a solution to this problem. Try to choose the encoder you need here. There is an excellent selection of various tools that have helped you in many of your projects. So if you need help, please contact me.
  1. variaxis tool height setter
    By r1cht in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-13-2018, 10:05 PM
  2. Replies: 1
    Last Post: 03-04-2014, 01:08 AM
  3. CRP's Proximity Sensor Kit
    By rwskinner in forum Avid CNC
    Last Post: 02-12-2014, 04:07 AM
  4. Wireless tool height setter
    By cd_edwards in forum DIY CNC Router Table Machines
    Last Post: 02-10-2012, 02:01 PM
  5. Tool Height Touch Sensor for Techno-Isel
    By mikkojay in forum DIY CNC Router Table Machines
    Last Post: 08-08-2006, 08:28 PM
