586,299 active members*
3,873 visitors online*
Results 1 to 7 of 7
    Nov 2014
    11
    DIY CNC Hot Wire Cutter
    Hello guys,I built my DIY CNC hot wire cutter and decided to post a new topic to show you what I made.
    The motors and the driver board are bought from eBay,the dealer is longsmotor.
    It is not something special but I am a beginner and I think it is pretty good for beginning.
    I used a wood construction because I don't have intention to use it for a commercial purpose.
    I use 0.300 mm kanthal with ressistance 19.1 ohms/m and the current I use to heat the wire is 1.3 amps.
    You can freely express your opinion and tell me what you like or dislike and if you don't understand something just ask.
    Nov 2014
    11
    Re: DIY CNC Hot Wire Cutter
    Don't you have opinions?
    Apr 2005
    253
    Great job, look forward to seeing what you cut. What software are you using?
    I'll get it finished sometime after I start it.....
    Nov 2014
    11
    Quote Originally Posted by robe_uk View Post
    Thanks!
    I use Mach3 for running the machine and ProfiliPro and AutoCad to draw airfoils and other possible shapes.
    Apr 2015
    I like it very much. I am going to make something like what you have made. Also wood or maybe some aluminium, if I can find it for free/cheap :-)
    Are you going to make foam wings? Or what is the main purpose for you? Mine is foam wings for gliders or dlg's.
    Nov 2014
    11
    Quote Originally Posted by Soaring View Post
    I cut some wings so far and tried to make my own free shapes but I would cut all that is possible to be cut with the machine.
    Apr 2014
    I dont see any pic?
  1. New hot wire cnc cutter
    By wantacnc in forum CNC Wire Foam Cutter Machines
    Last Post: 02-05-2015, 03:36 AM
  2. EDM wire cutter g-code?
    By Plecc in forum Mentors & Apprentice Locator
    Last Post: 03-24-2012, 10:13 PM
  3. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 10:15 PM
  4. Hot-Wire Cutter Software
    By Alonson in forum CNC Wire Foam Cutter Machines
    Last Post: 04-14-2008, 06:52 PM
  5. CNC Hot wire Foam Cutter
    By Krashlnd in forum CNC Wire Foam Cutter Machines
    Last Post: 01-17-2006, 02:57 AM
