fanuc machine--- tape and drill mate model t 1990 fanuc omc control
mistake # 1 changed back up batt. power off--------
power up---reset xyz to home manually as per instructions on screen
all went fine machine and control work fine EXCEPT for tool changer
t(x) mo6 will call up tool change program and will preform a tool change but will not rotate the carocell
because the z column gear falls short about 3/8 of an inch of meashing
with the carolell gear than completes the tool change action
this is the only thing that changed
