586,116 active members*
3,366 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Diamond cut end mill surface finish
    Oct 2014
    10
    I've been milling a lot of g10 fiberglass and have always used 4 or 5 flute 1/8" carbide end mill with 27k RPM, I get a get a good surface finish but they don't last long milling 3/16" material ,from reading around people recommended diamond cut or PCB because they tend to last longer .my question is what is the surface finish compare to am am using and if you guys have any tips that could help. Any info is appreciated .
    Apr 2009
    5516
    Re: Diamond cut end mill surface finish
    PCD WILL last longer... great surface finish. Only problem is that they are EXPENSIVE. I bought quite a few when I could, check eBay...
  1. Surface finish engraving with drill point end mill
    By Brian Corwin in forum Uncategorised MetalWorking Machines
    Last Post: 04-08-2014, 03:35 PM
  2. surface finish with a ball mill
    By david rendon in forum CNC Tooling
    Last Post: 05-26-2011, 03:50 PM
  3. bad surface finish
    By tunitime in forum MetalWork Discussion
    Last Post: 10-25-2009, 05:35 PM
  4. Using Diamond Cutters to get optical finish
    By cncron in forum CNC Tooling
    Last Post: 10-31-2008, 05:43 PM
  5. Surface Grinder Wheel - Diamond Dresser question?
    By widgitmaster in forum MetalWork Discussion
    Last Post: 06-27-2006, 06:00 AM
