He 3D - The Complete Open Source Delta 3D Printer Kit [He3D-DLT-A180] - $355 : HOYI SUNWAY LIMITED
Technical parameters:
1, the printing technology: the accumulation of fused deposition molding (FDM)
2, physical structure, parallel arm (delta)
3, overall dimensions: height:600 mm width:320 mm length:320 mm 4, the total weight: 10 kg (including packaging)
4, nozzle diameter: 0.4 mm (18, J - head hotend)
5, nozzle number: single nozzle
6. software: Repetier host
7, print range: 160 mm diameter hight 230 mm
8, power input: AC110-220 - v
9, the power supply output: DC 12 v 7 a
10, equipped with LCD screen
if you need ,you can contact me :[email protected] dream
