Re: Syntec 6MB Toll Setter
Ok this may be way too late but now that I've poked around a fair bit I have some added guidance.
Basically it may not be possible (without modification) on your machine unless it shipped with a tool touch off (TTO) sensor already. On mine (with a sensor) I think it might be easier as I already have a relay that is signalling when the TTO sensor trips and I could likely use that to set up a new one (with some parameter changes I'm sure). The syntec seem capable of different TTO sensors as I know Lee's is different than mine. However if none is set up now then they very very likely do not have it set up in the i/o ports or in the plc ladder. It should be possible to edit the PLC ladder file to enable it but I would suggest rotech do it. You might even offer to buy a TTO sensor from them if they can update the controller to use it and then attempt to change it out if you don't like it.
I just has some m-codes added to the PLC ladder for buttons that were set up on the console but not in m-code and all I had to do (eventually) was send the vendor my back up files and they sent me back a new cnc.lad PLC ladder file (which I restored on the machine). They did it in under an hour once convinced to do it.
So its possible but I found it helped a lot when I knew what I wanted and how it had to be done (as up until then they had said it wasn't possible - which I knew to be untrue, just lazy).
I plan to attempt to edit the PLC ladder in the future with OPENPLC (which is I think what syntec uses) but that's way in the future at the moment.
In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
