Brilliant!, thanks very much for that
Have bookmarked and will be going through it thoroughly.
Presently testing alignment and such, especially the 4th axis, rotary. Really-REALLY! pleased with how precise it is! Mounted an acrylic tube in the 'A' chuck, tube tested spot on in rotation; set a mini diamond-point bit in, loosened and set upon the tube, then tightened; plunged bit .01 with jog, ran it along the tube. It made a finely engraved line all the way, end to end, and I'm doing flips
Testing MDI commands to establish accuracy..., not so successful as yet. Just started doing this about 1/2-hour ago, so...I'm seeing override of commands. Jogged Z bit to engraved Y line just made, for approximate reference; entered G91 G0 A90 and...I think I need to set mach3 to process degrees. [ edit here to enter the following: errrm, happen to know how to set Mach3 to execute Degree commands? *red face* Yeah, it's like I have diapers on over here lol... end edit ] Entered A.9 (with decimal in there) and seemed to go a quarter, but entered 4 times it overshot the starting point about 10 degrees.... Anyway, that's where I'm at. Will be searching here for setting up A axis now... G91 G0 A90 <-- first MDI line ever, for the record :P
