Originally Posted by
claudiu220405
Hello,
Still the same problem.
What I saw is when I open a CAM part and then close that CAM part, there is starting the problem.
First time when I want to start a new milling process, the CAD part is closed, needed to open again and chose the milling process again.
If I don't press the OK button whent the new CAM milling process is starting, then I can open infinited parts and no error, but as I said, If I start or open a milling operation and close it, then I must open twice the same part for making a new milling process.
This is a big bug for SolidCam.
I also maked new regs for SolidWorks, and still the same problem...
Maby somebody have a solution and resolce this problem.
Greetings.
