586,100 active members*
2,716 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > AM882 heats motors up
    Jun 2013
    61
    Anyone use the AM882 drives? I just installed them and they seem to run fine except the motor gets very hot just while idling (not moving). I am only running it at 24V as my 60V supply isn't here yet. Also only using 2.7A setting for 3.0A motors. Using dip switches. I am using the 57BYGH633 motors from Wantai. They are supposed to be 3.0A motors. Wired using full coil. They were only sitting for a few mins and they got hot. They usually don't get that hot unless used for an hour or more.
    Appreciate any help anyone could provide.
    Andrew
    Re: AM882 heats motors up
    Do you have the current reduction enabled?
    Jan 2007
    1795
    the sw 4 need to be off
    means the stand still currecnt reduced to 60 percent to preventing the overheating..
    if sw4 is on then standstill current equal with the current..
    recently I changed a stepper, and this was so eyecatching within leadshine drivers..
    manual also says you can reduce more the standstill with protuner..
  1. HELP! C35 BOB: RJ45 to AM882 driver.
    By rotule in forum Stepper Motors / Drives
    Last Post: 04-05-2014, 05:36 PM
  2. RESOLVED! Mach3 MaxNC enabled = 1/4 speed motors , Disabled = no running motors.
    By BIWVince in forum Mach Software (ArtSoft software)
    Last Post: 02-22-2013, 09:28 PM
  3. Stepper motors or ac servo motors?
    By JIM at ATG in forum Commercial CNC Wood Routers
    Last Post: 06-13-2011, 09:10 PM
  4. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  5. HELP Power supply broken... Bridge rectifier smokes... Coil heats up.
    By Delanoman in forum DNC Problems and Solutions
    Last Post: 04-07-2009, 04:19 AM
