Re: BobCAM drilling rapid below clearance plane V27.
Originally Posted by
SBC Cycle
Clearance Plane - Z rapid height between features (always active throughout the program - "global")
Rapid Plane - Z rapid height WITHIN a feature (only active at feature level - "local")
Feed Plane - Z "Feed Switch" height (only active at feature level - "local")
That actually helps a bit. So if I understand correctly I could set the Rapid plane high enough to clear part+clamps, but maintain the feed switch at say 0.2" so I'm not drilling air for 30 seconds? That seems reasonable but the math would be different in each feature below the Z zero height. I'll try that out and see if that works better.
CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
