So I was working on a file this weekend and caught something in operation I didn't pay attention for in simulation. I had to drill a bolt circle down inside a deep bore in my part. The code generated seems to have generated rapid moves between the 6 holes that occurred at what appears to be the feed switch height of 0.100" above the start height. The result was that the tool was zipping from hole to hole while -1.2" below the material top. In the operation, the +2" clearance height is clearly indicated which I thought was mandatory for all lateral moves at rapid speed?
