Re: Jog shuttle - question
First thing I did when I noticed the pendant was "backwards" was to create a mental note on how it is the tool that which is moving. It had been a while since I'd owned a mill so that helped.
If you want the shuttle to be customizable, you can download the Shuttle Pro pendant driver from Artsoft's website. You will need to rename Tormach's so that it is not loaded. I think on that driver you can reverse motion. Hopefully I am not getting confused with the VistaCNC pendant...
I do recall you can assign functions to the buttons if you enable the Shuttle Pro Pendant drivers, although I didn't find one which I liked so eventually I just deleted the driver and went back to Tormach's default.
I also have the "beep" sound when I press a button. But be careful! Just because you heard the sound does not mean the axis was accepted! That is how I have lost plenty of edge finders and tooling... Darned unbeepery beep!
I document my CNC Experience at CNC Dude's Youtube channel. Check it out!
