I’m looking at buying a spindle & VFD for my first CNC machine that’s going to be housed in a residential garage. I'm a carpenter by trade and do make custom kitchens on occasion. But mostly using the CNC to make custom furniture as well for hobby work. The machine will not be used day to day and will sit idle most of the time. However I want to be prepared for anything that gets thrown at me in the future.
The spindle that I'm looking at
5.5kw (7.5HP)
380V
12 amps
400Hz
8000-24000 rpm
High Quality 5.5kw Spindle Motor/Water Cooling Spindle For CNC Router-in Machine Tool Spindle from Industry & Business on Aliexpress.com | Alibaba Group
I only have 240V single phase. So from what I have read I’m going to need to buy a 3 phase input VFD and de-rate it 50%. Am I right at assuming I need to buy one that has 380V input @ 24amp minimum with 380V output to match the motor?
This will all connect to a 30 amp breaker with 10 gauge wire.
The VFD that I'm looking at is
11Kw
380V input
380V output
24Amps
48-63 HZ input
0-400 Hz output
