586,047 active members*
3,837 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCAD profile tool path is not following the contour. How do I improve this?
Results 1 to 8 of 8
    Apr 2008
    51
    I have a simple part. This part is oversized by 0.375" for a secondary process. The problem is that when I create the toolpath, it ends up being inside that 0.375" allowance and at times, it comes very close to the "actual" part. How do I improve this toolpath?
    Pink = tool path
    blue = contour
    black = actual part
    Thank you,
    Ben
    Dec 2008
    4548
    Re: BobCAD profile tool path is not following the contour. How do I improve this?
    Go to the prefs-part-display settings and crank up the angle........
    Apr 2008
    51
    Hi BurrMan,
    Thanks for the quick reply, but I am unable to locate anything that says '...angle'. I see a transparency degree...?
    Should I look somewhere else?
    I have V25
    Dec 2008
    4548
    Quote Originally Posted by benjamint76 View Post
    Hi BurrMan,
    I have V25
    sorry. There are 2 sliders. One for lines and 1 for surfaces. Maybe they say "quality".... i forgot and am not at computer. They represent the viewport "mesh angle"
    Edit. Just got a look at your image. It is the surface and wireframe sliders. I see your wireframe is all the way up... maybe need the file to get a look at
    Frik. Shading not surface.
    Apr 2009
    3376
    Burr,,he uploaded a file on the BoB forum.
    As Burr said your wireframe slider turn it down.
    I still could not get it dialed in perfectly.
    Maybe its just the fact of such a large model.
    I do not believe what you see on the screen is how it really is.I believe it will cut correctly.
    Love to see your set-up..Not familiar with hot wire.
    Dec 2008
    4548
    I put a file up over there for him. Here's the reply:
    Delete contours and run explode-lines at .0001. Then run contour on both items and reselect geometry for the profile op…
    It has to do with those super long 3 point arcs and tolerances for the contour command and what the profile op is reading.
    Remove the contours and then explode those huge arcs into a million pieces. You can then rerun the contour command and toolpath it ok...
    Apr 2009
    3376
    Well done.
    If he would of just ran the part, would it of been OK?
    I mean is this just a graphics issue or does this affect the model and tool path ?
    After Exploding,,you most definitely would want to contour it,right ? Otherwise you have a million little line segments that are bound to make things choppy on the cutting,,,is that a correct statement?
    Thanks for more knowledge Mr. Burr
    Dec 2008
    4548
    Quote Originally Posted by jrmach View Post
    Well done.
    Not graphics. Imternals. Yes, the toolpath would be off.
    The second question is a good question. I assumed making the contour after the explode would handle that part but i could be wrong. This is where v27's rebuild was welcomed.
  1. Problems with profile tool path
    By Bobcef in forum MadCAM
    Last Post: 02-28-2014, 02:36 AM
  2. Multiple profile operation tool path issue
    By Craigpat in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-25-2014, 09:38 PM
  3. Profile tool path
    By Bradferguson in forum PhotoVCarve and VCarve Pro
    Last Post: 01-17-2014, 03:54 AM
  4. Replies: 10
    Last Post: 09-05-2012, 03:30 AM
  5. Different tool path with different profile
    By vcatalasan in forum Mach Software (ArtSoft software)
    Last Post: 08-18-2011, 06:28 PM
