Specification
l Input: AC220V or AC110V
l Power: 60W
l Current: 23mA
l Dimension: 224X150X100mm
Technical parameters
Input Voltage
AC220V or AC110V(to be specified when placing order)
AC Input Frequency
47~440Hz
Over current Protection
Yes
Open Circuit Protection
Yes(short term)
Cooling way Fan cooling
Working Temperature
-30℃~65℃
Relative Humidity
20~85%RH(no condensation)
Vibration Resistance
Amplitude: 1mm frequency 30Hz Two hours
Aging time Continuous>4 hours Pulse>Half an hour(frequency 60Hz)
nstallation
1. Connection of laser tube
The high voltage (HV+) of the laser power supply shall be connected to the anode (full reflection terminal) of CO2 laser tube. The current circuit of the laser power supply is connected to the cathode (laser output terminal) of CO2 laser tube through an ammeter (or directly).
2. Connection of control signal
Control signal shall be reliably connected to control terminal of the power supply.
3. Input of control signal
After connecting the output signal and TTL signal of external computer with the power supply, the laser tube shall work as expected.
