Re: Belt Change Help
Originally Posted by
RussMachine
M00 stops with a note in the program is the easiest way.
We've done this for a lot for fixturing and vise / clamping changes during a program run.
The best way to idiot-proof it for operators is to make 2 back-to-back M00 stops with back-to-back notes.
Example:
M5
M00
(Change Belt)
M00
(Did you Change Belt?)
M3 S1000
When the spindle stops, it's usually common practice to look at the program to see what's up. So the 'Prompt' is just a note in the program.
M0 restarts the clock f you're keeping time of your cycle time. You could accomplish the same thing with an M6 and you wouldn't lose tour cycle clock.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
