Hello to everybody,
i have a problem with the siemens acramatic2100.
Am trying to pocket mill using G26.1 pocket milling.
But the diameter is coming out totally wrong,for example,trying to mill a 4 inch dia hole,the dia is coming out at 3.6 inchs.
Also using helical ramp it is leaving a small dia pip in the middle (easily solved with a seperate op)
As for the dia problem,have checked and rechecked all parameters,checked the tool table.
Is there a setting somewhere else that some one may have changed in the past,or do we have a software problem ?
We have tryed various dia's but with the same result,always coming out smaller than programmed.
Any help would be appreciated,
thanks,
Paul.
