586,042 active members*
3,718 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Colombo ATC Spindle help....
    Apr 2013
    I'm converting a Techno CNC router to steppers and Mach3.
    I got a screaming deal on the machine....But....It has a 7hp Colombo ATC spindle. I have found no technical info anywhere on how to interface to this Spindle/ATC. I know I can control this thing with a macro in Mach. But I need a connection diagram in order to hook up my relays to the Spindle/ATC controller. Even a pinout of the connectors would help a lot.....
    Hoping someone has done this before....
    TIA,
    Dave Ganzer
    Oct 2012
    5
    Re: Colombo ATC Spindle help....
    Hi which connection diagram you need i made cnc router used with Colombo spindle vfd which you are using? there is no need to macro to operate with mach 3 im doing it on from pwm it very simple my dear i did tried my self my cnc working now 12 hr per day continue what you need let me know.
    mukesh.
    Jun 2019
    5
    Hi
    I also have a Colombo spindle im trying to hook up
    its a RS 110.22 ISO 30
    i was able to get these diagrams from PDS (they're awesome)
    but
    i only have 220 volts power and want to make sure i hook it up properly
    please see pics
    any info is greatly appreciated
    Aug 2011
    68
    Attached Files Attached Files
  1. A few ?'s for the Spindle guys, Colombo.
    By Flateric in forum DIY CNC Router Table Machines
    Last Post: 03-06-2013, 10:45 AM
  2. Colombo Spindle wiring
    By powerfade in forum CNC Machine Related Electronics
    Last Post: 09-19-2012, 04:16 PM
  3. old colombo spindle
    By petercolombo in forum CNC Tooling
    Last Post: 03-29-2012, 08:35 PM
  4. need help on a Colombo spindle
    By contactirfu in forum Phase Converters
    Last Post: 09-03-2009, 01:33 AM
  5. 3HP Colombo Router Spindle + VFD for under $2k
    By blurrycustoms in forum News Announcements
    Last Post: 06-09-2009, 03:59 PM
