Need 2 pcs - 1/8 x 1-1/4 x 24" steel or aluminum flat stock with 18 holes (.135-.140"*) all drilled thru located .20" from one long edge and spaced 1.301" from each other starting 1" from one end.
plus 4 pcs - 1/8 x 1-1/4 x 15" same stock with 11 holes (same size*) also .20" from one edge, spaced 1.287" apart starting 1" from one end.
*holes should be all the same size = anything between .135 and 9/64 is ok - whatever is easiest.
Shipped to 49631
