586,114 active members*
3,311 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Looking for a Substitute to Acurite Millpwr AMI
View Poll Results: Is there a Substitute to Acurite AMI
Voters
1. You may not vote on this poll
  • yes
    1 100.00%
  • no
    0 0%
    Apr 2015
    I have a full size lilian milling machine with 3 axis controlled by acurite millpwr.
    The time has come to add an indexer or rotary axis.
    Acurite's AMI (controller) is very expensive and loaded with more than i need.
    Does anybody know of a control board substitute I could use for adding this axis.
    This is the AMI I am referring to from acurite (over $1000.00) i need something simpler but compatible.
    http://www.acu-rite.com/pdf/manuals/AMI_Manual_Ed_D.pdf
    Thank You
    CNC Zone is excellent!!
    Thank You to all. I am so glad to have found this website.
    I have good knowledge of machining and turning with specialities in high production.
    Please feel free to contact me with questions.
    I am looking through posts and finding I can help solve many small problems.
    I hope someone can help with my current troubles.
    Jun 2007
    394
    Re: Looking for a Substitute to Acurite Millpwr AMI
    Sep 2012
    13
    Have you found a solution for this yet? I would like to set up something similar
    Mar 2011
    67
    This is a little hokey but you could mount a small switch somewhere that when the quill fully retracts it closes the switch. Use that switch to close the index start signal. Dwell the control for an appropriate amount of time before resuming.
    Haas used to make a switch that clamped onto the top of the screw where the z stop nuts are. On a manual machine or a 2 axis you'd raise the quill all the way to hit the switch to start an index.
  1. Acurite MillPwr - can we customise names in the "Tool Type" table ??
    By rayg in forum Bridgeport / Hardinge Mills
    Last Post: 12-09-2013, 10:11 PM
  2. Acurite MillPwr - connections for edge finder / probe
    Last Post: 04-24-2013, 10:33 PM
  3. Acurite Millpwr 3 axis Controller
    By landissam in forum Controller & Computer Solutions
    Last Post: 12-26-2012, 03:16 AM
