586,110 active members*
3,354 visitors online*
    Jun 2004
    55
    mach3 question
    hi , im retrofitting a machine with mach 3, pmdx 126 breakout board and panasonic servo drives and motors, i have movement on axis now , but always in same direction , mach3 displays show correct movement but axis goes in same direction, i can change motor output pin numbers and direction changes but still goes in only 1 direction same if i change parameter on drive , direction of movement changes but goes same direction whether jogged in + or - direction.
    thanks
    robert brintle
    Apr 2004
    5737
    Re: mach3 question
    Double-check your wiring. Usually that's the cause of this sort of error.
    Andrew Werby
    Website
  1. Mach3 question
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 09-29-2011, 01:41 PM
  2. Mach3 Question
    By binfordw in forum Benchtop Machines
    Last Post: 12-14-2010, 10:09 PM
  3. mach3 question?
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 09-18-2009, 05:35 AM
  4. G-251/Mach3 question
    By alphamail in forum Gecko Drives
    Last Post: 11-06-2008, 10:14 AM
  5. Mach3 question
    By cosmynnec in forum Mach Software (ArtSoft software)
    Last Post: 05-01-2006, 07:46 PM
